Roger Chatfield
Interior festoon lamp size
Evening chums, quick one for you.
Does anyone know what size the interior lamp is, the festoon bulb. I think it's 38mm, I want to get a led replacement and need what size to order.
Thanks
Rog.
I think 38mm is for the map, glove box and boot. From memory the courtesy light is 43mm? I'll measure mine tomorrow if it's not answered by then.
I have had a bad experience with the replacement LED lights. I changed the boot light bulb as I thought the LED would be significantly brighter. Unfortunately it only offered a feeble light that in my option was worse that the original. I'm sure there are reputable suppliers out there, but you need to be careful and check the specs.
