VEEDUBBED
Quite a few bits..
Right guys,
Quite a few bits unearthed to sell, let me know if your interested in any, just include your email as i still haven't worked out
how to post photos up on here..
2x large Brembo calipers, they were fitted to Lancia k turbos, not to be confused with the smaller Ford focus rs or Fiat coupè T.16v jobbies, a lot bigger, everything included, pads, bolts, antirattle springs etc. £120 posted.
Audi 5cyl. cut down manifold with ext. wastegate and spare uprated spring that should hold 1.3Bar, comes with an excellent Volvo derived Mitsu. TD04 turbo. The manifold has been modded to accept any T3 series turbos with a bolt on flange. The manifold has a couple of cracks but they're all are cracked, unless brand new..£250.
KKK oil cooled turbo, i think it's the original version fitted onto the 1982/3 quattro as the date stamped on the turbo is '82, this comes complete with an Audi 8v turbo manifold with lambda boss, the usual, unavoidable small cracks. £300.
Original 2.0 9A pistons and rods, full set £80
Audi S4 aluminium intercooler off a 5 cyl 20v turbo mill. £100
Italian made Turbocar 16v turbo manifold, very well made and it's also divided so you could use a twin scroll Garrett turbine housing if you wish. £120.
Complete 2.0 9A cyl.head with reprofiled original cams, no idea who did them as it was years ago. £150
4x Audi S3 Bosch injectors, light blue versions with long snout, should be around 385cc. £100.
4x Late style headlamps. £50 each.
Old style seperate fog lamps £25 each
A few sets of new style fogs/indicators, excellent condition.
16v 9A valver exh.manifold, off an engine that had 30.000km. £50.
Vr6 complete cyl.head, off a 19.000km engine,cams, exh. Manifolds, injectors all still attached. £200.
Vr6 2.9 ABV engine bare block, 19.000km from new. £150.
Ecu for above engine (Dist. Version) £ 80.
6x pistons ABV 2.9cc, no rings though complete with conecting rods £90.
Crack pipe. £20
Dist. with leads,rotor and cap. £80
Sump. £20
Oil pump. £50
Downpipe. £50.
Timing covers. £40.
Crankshaft complete with all bearings and vibration damper £100.
All parts of same low milage engine.
I'll add more as i unbox.
Edited by VEEDUBBED
