Rich the Chef 10 Posted October 30, 2015 Just looking to fit new top mounts and stops to my VR6 Corrado as I'm putting some coilovers on. I figure it's worth popping new on while its in bits and then I only track and camber once. What is needed and who or what's recommended? Poly or standard? I don't want to miss anything out and want to put a full strut with all new parts in place of the OEM stuff. Thanks Quote Share this post Link to post Share on other sites
fendervg 32 Posted October 30, 2015 I'd go for VAG or OEM quality parts, don't go poly for the top mounts as it will be too stiff in my opinion. The rear lower mounts are only available through VW Classic Parts or Heritage in the UK. Lemforder do repair kits for the front and rear top mounts and are decent quality - I can get the part numbers for you if you need them. These are the VAG part numbers: Front strut mount 357412331A x 2 Front strut top mount bearing 1J0412249 x 2 Rear strut mount upper 191512335 x2 Rear strut mount lower 191512333 x 2 (only available from Classic Parts) Bump stops etc. should be readily available. Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted October 30, 2015 Thank you very much that's really great help. Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted October 30, 2015 I've just bought a Febi kit of upper and lower rear mounts. Just looking for the fronts and I'm all set. Awesome. Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted October 30, 2015 Bought fronts now too. All Febi (Bilstein) OEM and free postage too. Thanks again for the help. Quote Share this post Link to post Share on other sites
cmalyan 11 Posted October 30, 2015 I've just bought a Febi kit of upper and lower rear mounts. Just looking for the fronts and I'm all set. Awesome. Hey, would you have the links to the front and rear kits you purchased please? Thanks! Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted October 30, 2015 Yes I bought it from eBay. Seller is a shop called Murrays_direct. Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted October 30, 2015 http://www.ebay.co.uk/ulk/itm/150769583498 Pair Lemforder & Febi Front Top Mount Kits VW Mk3 Golf Passat Sharan Corrado VR6 Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted October 30, 2015 http://www.ebay.co.uk/ulk/itm/151525990212 Set of 4 FEBI Top Rear Suspension Mounts for VW Mk2 Mk3 GTI 16V G60 Corrado VR6 Quote Share this post Link to post Share on other sites
cmalyan 11 Posted October 30, 2015 Great - thank you! Quote Share this post Link to post Share on other sites
