unclean 10 Posted November 22, 2015 I cannot for the life of me get the brake servo out! There's no engine in the car and I've moved the M/C out of the way, but I can't figure out how to get it out from behind the shock tower. Any tips on how to get it extracted (pull it up, or out sideways, or down?) would be much appreciated. Cheers, Phil. Quote Share this post Link to post Share on other sites
leon263 0 Posted November 22, 2015 The servo is bolted onto the bulkhead and also clipped onto the brake pedal. You will get access to the four bolts from up behind the dash and while you are up there you will see where it is clipped onto the brake pedal. Remove the bolts and clip if you have not already done so and the it's just a case of wiggling it about to get it out ........ form memeory it is a bit of a faff. Quote Share this post Link to post Share on other sites
unclean 10 Posted November 22, 2015 Thanks Leon. I managed to get the four bolts holding it to the bulkhead out (after much hassle) and the clip removed earlier, just stuck on the wiggling part. Any directions about that? I assume I have to tilt it to the right for the rear to have enough room to come free? Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 22, 2015 should just pull free Quote Share this post Link to post Share on other sites
