Guest petercabrio
Fan runs flat out whenever ignition on
Guest petercabrio
This is confusing me. I changed the coolant today and did a rad flush too in an attempt to get heater working properly,(another story)
Flushed system through, with rad clean and then topped back up and put antifreeze in
Warmed car back up the header tank cap off to let air escape. Everything worked fine, all hoses warm, fan kicked in and out ok on low speed, temp gauge never over 90
Then fan starts running full speed and temp dropped to 70 and fan still running
I have left it to cool right down and turn ignition on and fan runs full speed. Any ideas
E
What engine? I had this in my vr. Through unplugging the sensors on the housing at the front of the engine I narrowed it down to one of them. I replaced all three, but the yellow one is for the ecu, the blue for the dial and the back for the fan control if I remember correctly, although it's late and I've had a beer or two lol
Guest petercabrio
Taken all sensor wires off, Still running flat out
Guest petercabrio
That's the one, disconnected fan stops, back on and it runs, faulty sender. Thanks
Guest petercabrio
changed the fan switch in radiator and now it doesnt work at all. even put the old one back in and still doesnt run
Guest petercabrio
And without doing anything its working. Gets warm and then fan ticks on and off happily
Can't unstand. But it's working
