Reverend Frog 10 Posted December 7, 2015 Having done a few searches on here I am pretty sure that my valve stem seals are nadgered. I’ve got a 2.9 VR6 with 97,000 miles on it. After it’s been allowed to overrun (engine braking) downhill and when I try to pull away afterwards, it bogs down monetarily and produces a puff of smelly blue smoke from the exhaust. So I have two questions: How much, typically, would I expect to shell out for a top-half rebuild to rectify this? I have noisy tappets so would consider getting these looked at while it’s in for the work. (The previous owner claimed it had had a top-end rebuild in recent times, but I can’t remember why it needed it). Will I ruin the car by continuing to drive it until I get this remedied, or shall I just keep the oil topped up and avoid hills ? Cheers Quote Share this post Link to post Share on other sites
subcool 0 Posted December 7, 2015 Sounds like worn pistons had the same problem myself and it wasn't the head!! Quote Share this post Link to post Share on other sites
Reverend Frog 10 Posted December 7, 2015 Sounds like worn pistons had the same problem myself and it wasn't the head!! worrying, but thanks! How did you get it fixed? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted December 7, 2015 hello reverend the first of your questions is very tough to answer but from personal experience it can turn out costly. at a guess maybe around the £1k to £1.5k depending on what is exactly done (but be prepared for much more! my budget went right out the window & into the ether lol) I would check out your cars history for the rebuild info as if it has already had a top end rebuild they should have replaced the valve stem seals - which can cause your blue smoke do you get any blue smoke on the first start of the day after leaving over night? reason I ask is that is a classic sign of valve stem seals on their way out - as the oil seeps past them over night & into the combustion chambers, thus resulting in a blue smoking on first start up that can then go away whilst it is running. I had a top end rebuild along with some subtle mods a while ago, take a look at my build thread for an idea of what I replaced & what ailing components then also needed replacing due to them being weak links in the chain http://the-corrado.net/showthread.php?44751-g0ldf1ng3r-s-VR-amp-1-8-16V-headlight-woe-s/page2 as for the 2nd question - I wouldn't imagine it would do much if any harm to drive as it is. it may have a long term detrimental effect on the CAT but like you say just make sure you keep the oil topped up & it should be ok by all means ask any questions you may have :) hope that helps Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted December 7, 2015 Sounds like worn pistons had the same problem myself and it wasn't the head!! potential OUCH! Quote Share this post Link to post Share on other sites
subcool 0 Posted December 7, 2015 worrying, but thanks! How did you get it fixed? Full rebuilt new big valve head cost around £3k plus by tsr performance in Somerset! Quote Share this post Link to post Share on other sites
Reverend Frog 10 Posted December 7, 2015 do you get any blue smoke on the first start of the day after leaving over night? reason I ask is that is a classic sign of valve stem seals on their way out - as the oil seeps past them over night & into the combustion chambers, thus resulting in a blue smoking on first start up that can then go away whilst it is running. I don't believe so - I get condensation from the exhaust on first start-up, but I'm pretty sure it's not oil smoke. If it wasn't for having to negotiate hills i wouldn't even know there was a problem with the car at all. I suppose the main issue here is - how do you find out what it is without taking the engine apart? which is going to cost you regardless Quote Share this post Link to post Share on other sites
subcool 0 Posted December 7, 2015 If it's using a litre of oil every 500 miles and smoking on the over run then it's probably fooked like mine was! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted December 7, 2015 I don't believe so - I get condensation from the exhaust on first start-up, but I'm pretty sure it's not oil smoke. If it wasn't for having to negotiate hills i wouldn't even know there was a problem with the car at all. I suppose the main issue here is - how do you find out what it is without taking the engine apart? which is going to cost you regardless I had the condensation issue too before my head work & before I got my longlife SS exhaust - it was the old CAT holding moisture. IIRC if you rub the smoke between your fingers you can feel if it is oily or not how much oil are you using? the VR really should use much at all. I know mine normally uses maybe between a 1/4 to 1/2 a litre over 10,000 miles. IE only requires a very small top up on a couple of occasions between oil changes. as you mention in your last sentence it is very difficult to pinpoint a suspect, if any, without taking it all apart. has your had the chains & top & bottom tensioners done? if not you could have the head inspected whilst the rocker cover etc is off I wonder if a compression test would help point you in the right direction. IE would it show lower compression on a chamber if say the piston or its rings or the chamber itself were worn? I would imagine so. that potentially could help you identify if it is top end of bottom end either way, & whatever you do, I would advise trying to allow for at least double whatever the intended budget may be to allow for the replacement of other ailing parts which become weak links Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 7, 2015 Sounds like worn pistons had the same problem myself and it wasn't the head!! +1 I had the head done first, thinking the smoke was caused by worn guides/seals, but the increased vacuum made the smoke worse! It was the classic ovalising of cylinders 1 & 6 but switching to Silkolene 10W50 certainly reduced the smoking considerably. If plugs 1 & 6 are caked in a white crusty substance, or are wet, it's definitely bores. Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted December 7, 2015 If it's only on 97k it would be unlikely to be a bore issue but yeah check the plugs, especially the two outer cylinders 1 and 6. But it is not a definative test. Plus cylinder wear is likely to smoke badly when up the top of the rev range. The classic 'smoking after engine breaking down hill' tells me that it is stem seal related, particularly worn valve guides causing the seals to fail. Overun / closed throttle creates a vacuum that sucks the oil down past the seals then spits it all out the back in one go in a lump of blue smoke. Of course bad rings and bore wear can do this but they'll usually be accomplished with other symptoms like burning under load and excessive crank case pressure. Compression and leak testing may be worthwhile if there is doubt before stripping. Quote Share this post Link to post Share on other sites
