MZpog
HT leads for valvers
Been looking at new HT leads as I fancy a bit of colour rather than black.
Noticed that the 1.8 and 2.0 leads are listed separately, the 2.0 costing more.
I've never owned a 1.8 but presumed it'd be the same layout as the 2.0 and that they'd use the same leads.
So what's the difference?
there's a sensor on the coil lead for the 2L ecu
I'm sure mine doesn't have one - is it necessary? Where does it plug in?
You should have it, though I've never fully understood the impact / usage as the car will run seemingly fine without it connected. Apparently it helps detect knock / pinking.
It should be on the ignition lead for cylinder 4 and connects to a plug, which runs off into the ECU I think.
It's not exactly like this one, but similar...
http://www.volkspares.co.uk/Shop/images/030905377-knock-sensor.jpg
Well the car hasn't missed it for the last 2 years and runs spot on.
I'll have to have a look for a spare plug.
