dythama 10 Posted December 18, 2015 Hi guys, I need a water pump bolt for my 16V, part number 051 260 821. I only need one as pictured on the left of the picture below.These longer bolts are used to secure the bottom of the water pump. Does anyone have one they can spare? [ATTACH=CONFIG]82811[/ATTACH] Thanks in advance. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted December 25, 2015 I'll have a look later on, i've Got a box of valver/g60 bolts. Quote Share this post Link to post Share on other sites
Dox 31 Posted December 25, 2015 Why not use a length of studding and slim nuts? Quote Share this post Link to post Share on other sites
aki 0 Posted December 26, 2015 Hi What dox said! Or even an old bolt thats long enough and threaded all the way up cut the head off screw into hole then if its crucial for alignment of whatever goes on the end cut and or grind or file a nut down so its the same thickness as the existing bolt head tighten it down and the use another regular nut for whatever goes on the end If alignment isnt important just use a regular unabused nut Thats what id be doing if i was stuck with a car that didnt work just because of a bolt missing at least then you can still use it whist waiting to get the right bolt Aki Quote Share this post Link to post Share on other sites
