Mrbaldhead
Sump leak
So during having my alloys refurbished today I had a look around the car....... and noticed this leak :(
Its parked in the garage and has never left any oil on the floor so must be a recent leak and its not dripping only wet. My knowledge in this is poor so what do people think? Does it need taking to bits and new sump gasket?
Its hard to tell from the pics . I would get some engine cleaner and give it a good scrub . Get the engine as clean as you can . When the tell tale leak returns you should be able to pin point it easier .
Id double check the rocker cover gasket on that side at the top of the engine if that fine then yeah sump gasket
