delfinis38 1 Posted February 4, 2016 I've only ever had 3 batteries in the corrado.. Last 2 lasted about 7 years each. My latest Bosch s4 has lasted 3.5 years.. I know they are guaranteed for 4 years. But I don't use the battery as it should be used ... Ie... Car never moves battery gets charged every month on the 1st of the month. So I won't be claiming my guarantee. So which battery should I buy this time... Any one tried a Duracell. Quote Share this post Link to post Share on other sites
G60_Chris 11 Posted February 4, 2016 You may be better off with the Halfords 3/4 year guarantee batteries... Not sure if they're all the same, but the local store here doesn't even check them before swapping them over! Alternatively, a solar charger may be the way to go to ensure it's kept charged up etc. Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 4, 2016 I don't think Halfords supply Bosch ones anymore. I got a Yuasa one last time I had to change one there. 5 year guarantee so should last a while at least. I'd always use that guarantee and get a new one if it failed before time. Well over £100 each time is better in my pocket than these major companies who do well out of those that bin the receipt or do as you're doing and not bother. Its your choice and I'm not judging don't get me wrong! I'd just use the guarantee if I could. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted February 4, 2016 I'm in same boat, car gets driven once or twice a month during summer so battery has died Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted February 4, 2016 Buy a ctek charger! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 4, 2016 I agree with Sean and will I dub. Get a replacement yuasa battery and a ctek msx 5.0 :) Quote Share this post Link to post Share on other sites
jekel 10 Posted February 5, 2016 I've only ever had 3 batteries in the corrado.. Last 2 lasted about 7 years each. My latest Bosch s4 has lasted 3.5 years.. I know they are guaranteed for 4 years. But I don't use the battery as it should be used ... Ie... Car never moves battery gets charged every month on the 1st of the month. So I won't be claiming my guarantee. So which battery should I buy this time... Any one tried a Duracell. Eurocarparts had a cracking deal on Bosch's just before Xmas, got an S4 for bout 55 quid from memory, tey had cheaper Bosch's but got the biggest one for car (think it was S4), they also did Duracells and most others, check them out. Google Europarts offer code and there's some site that always has latest offers and code, and do the clikc and collect as it's cheaper, I got a discount on a discount, effectively. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted February 6, 2016 My battery is starting to feel the strain as the car hasn't been driven too much this winter, i have a Varta fitted, been in the car for 4 years plus. Been quoted £45 for the same one, not too bad tbh. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 6, 2016 Thanks Sean.. I will look for my receipt today. :) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 6, 2016 45 quid seems very cheap.. Eurocarparts supplied a Bosch S4 60Ah for me just a few weeks back at £58 - saved my bacon and nearly £20 cheaper than anywhere else. Only one way to prevent car batteries dying on a car you don't use much and it's to keep it on a trickle charger when you're not using it. TBH all lead acid batteries are pretty much the same within the mass market, so buy the one you get the best price on, but I wouldn't fit less than a 60Ah on a VR6 myself. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 6, 2016 I would be very cautious about having it plugged into the mains all the time. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 6, 2016 I would be very cautious about having it plugged into the mains all the time. Me too, if the charger wasn't designed for it you'd kill the battery in short order. Fortunately they are designed for it. http://optimate.co.uk/optimate%205.htm Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 6, 2016 It won't help everyone but when I had a car off road over the winter I swapped the battery with the one for the daily once a month. Only takes ten minutes and seems to keep the batteries active and last a lot longer than just sitting in the car with the occasional charge. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 7, 2016 Basically a lead acid battery degrades during any time that it's not fully charged. Keep it fully charged for all time and it will literally never fail. Unfortunately the cold start pulls one or two Ah of capacity out of the battery each time and it takes five to ten minutes of solid charging to replenish it. Quote Share this post Link to post Share on other sites
