Tizedes
2.0 16V Engine Vacuum Routing
Hi Guys,
I have a little problem on my 2.0 16 Valve vacuum system.
Any has a engine vacuum hose drawing please?
I just would like to identify one hose because I have broken it.
Hose is from under the air box goes up next to the throttle body.
It was a white plastic hose. I have tried put back and brake it unfortunately.
Anyone knows where I can get it or how to replace it?
Any help would be much appreciated
can't find a 2L diagram but the 1.8 should be similar
If you can't find a replacement rigid vac line (ebay?) then just use a long length of vac hose
Thank you for your help. It is similar.
I do not know how it is call exactly I cannot find anything on this name.
Do you know how it is call exactly? Two pipe going to the temperature regulator does it matter which in a right side or left side?
