bigpants baby 0 Posted July 4, 2004 hi chaps,thinking of turning my c into 4wd,what donor vehicle would i need? would an old golf or jetta synco be any good? Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted July 4, 2004 tell me more? have you to alter the floorpan or exhaust? Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted July 4, 2004 err, you have to do a lot more than that Not for the faint hearted. The rear boot floor needs to be replaced for the syncro item You will more than likely have to make an exhaust up from scratch Syncro fuel tank needed syncro back axle (obviously) etc etc A bit more than a weekends work Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted July 4, 2004 theres a 91 jetta syncro for sale is it worth getting something like this or newer? Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted July 4, 2004 depends how mechanically adept you are, or how much money you have to through at the car. but yes if you were thinking of doing it then that sounds about right. Bare in mind the syncro rear viscous coupling is not as good as the rallye one. Quote Share this post Link to post Share on other sites
crazymarcel 0 Posted July 4, 2004 Surely a Jetta's syncro system is only gonna be good up too so much power(not much), would it not be be better seekin a Rallyes system. Quote Share this post Link to post Share on other sites
polog40racer 0 Posted July 4, 2004 Richard Tweedle (all smiles) reckons the Corrado shares the rallye's floorpan (well, transmission tunnel) and a 4wd swap is fairly straight forward. Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted July 4, 2004 thanks for the advice :wink: Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted July 5, 2004 I have a jetta syncro floorpan in the shed if you need one. probably easier to buy a whole syncro though.,. even then, the gearbox and rear diff are pretty useless as they can't take big power. but the boot floor and tank and the axle itself might be useful, even though they have drum brakes.. Quote Share this post Link to post Share on other sites
MelG60 0 Posted July 15, 2004 You need to raise the boot for the fuel tank. The normal mk2 Golf Syncro has a weaker 4x4 system.... You can use it but it will break easy. Quote Share this post Link to post Share on other sites
