richman711
steering column lower bearing
Hi guys
I've had play in the steering of my rado since I've owned it, I've slowly narrowed it down to the lower bearing in the column ( I'm guessing there's a bearing there)
Basically i had column to rack UJ shaft disconnected earlyer and I could wobble the end of the column a good 5mm in each direction
Has any one changed one before? And more importantly is this play I've mentioned normal (pretty sure it's not lol)
Cheers
Kyle
Edited by richman711
If you do indeed need a bearing I'm throwing away an old Colum
That is fine (I've got another two spare).
Let me know and I'll get the required bits off it for you.
