VR6 Lee
Crank pipe fitting
To secure the crack pipe in position what sealant did everyone use?
I just want to make sure it's stays water tight when everything is back in place
Edited by VR6 Lee
'Crank' pipe? Never Heard of it mate.
Crack pipe that runs across the block yes, i use clear silicone grease.
Never had any problems and Always easier to remove if needed.
yea same here with silicone grease, make sure the sealing surface on the block is clean and smooth and rust free, if its not then smooth it out with sand paper,
Come on Lee you know its the crack pipe.
Sent from my SM-G900F using Tapatalk
Typo bro
