Longjon 10 Posted June 15, 2016 Ok, so I was having issues with temp gauge not working in the car so changed the sensor, still didn't work, Using the cooling guide I decided to test the fans, Only stage 1 works, not 2 or 3. I removed the fan control module and when its off it rattles like something is loose inn there, I take it this is not normal? !, Mine is part number 1HO 919 506 and has the 2 plugs on the bottom, after phoning TPS and VW heritage i found out the part is obsolete, 2, Does anyone have one I could buy from them 3 Anyone local have one I could borrow to test my fans 4 Has it been superseded by a newer part. 5 Does this bit by not working affect the dash temp gauge. Cheers JOn Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted June 15, 2016 Hi Jon I have one if you wish to try it Quote Share this post Link to post Share on other sites
Longjon 10 Posted June 15, 2016 That would be fantastic cheers. Where about a are you Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted June 15, 2016 bishop auckland county durham Quote Share this post Link to post Share on other sites
Longjon 10 Posted June 15, 2016 How much do you want for it as I'm in Dover!! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Longjon 10 Posted June 15, 2016 Just to confirm the part no 1HO 919 506. Cheers Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted June 15, 2016 this one ends with an 1HO 919 506 A I know I have others too Quote Share this post Link to post Share on other sites
Longjon 10 Posted June 15, 2016 Deal, pm me your email, PayPal ok? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
tman2714 0 Posted June 15, 2016 Hey lilfuzzer. Sounds like I might need one of those too. Need to work out which thought. Mines a 1990 1.8 16v. Any ideas? Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted June 15, 2016 tman2714 said: Hey lilfuzzer. Sounds like I might need one of those too. Need to work out which thought. Mines a 1990 1.8 16v. Any ideas? send me a pic of your part number mate and I'll take a look Quote Share this post Link to post Share on other sites
tman2714 0 Posted June 17, 2016 I can't actually see a fan control unit near my coolant tank. Do the 1.8 16v engines have a run on control unit? Quote Share this post Link to post Share on other sites
