Arubberducky1
Ignition
The first time starting my car in the morning is always no problem but every time after that I have issues trying to start my car. I'm starting to believe that it is my ignition where the key turns in itself because i got my starter tested and it's perfectly fine. Sometimes jiggling my key inside works ever so often but now i have to push start my car whenever I go out places. Some help would be great just trying to solve my problem. Car is a 1990 Corrado G60.
Replaced mine this week - got part from eBay (£5.80 iir from B and B components, username tierod69 )... Fiddly to do but manageable.....
Worth changing the ignition switch.. Their is a how too in the wiki.. Your need to bend a few screwdrivers to get the old and new switch in.
Hijacking the thread here, but relevant - my ignition switch on my '91 G60 has never given me any troubles, but would it be worth changing it out anyway as a preventative measure?
I never had a problem with the switch itself, but it was the switch positive feed that didn't work in the switch so the radio a few other bits never worked... In my view they do break down... Fiddly to change.
