ryan_welshman
Carb balancers
Hello all
Need to turn the carbs and fancy giving it a go myself. Anyone know a good balancer tool thats not stupid money?
To be used on twin 45mm dellorto carbs
Cheers
Doesn't have seperate butterflies per cylinder but if you have one spare with all the pieces to it and dont need it then ill have it off ya
Sent from my SM-N9005 using Tapatalk
Not sure it'll work without separate butterflies as you partially block the intake with the black cone part, which obviously won't block if the other is open to atmosphere. You can give if a go if I find it. I'll have a rummage in the garage over the weekend.
