carrots 1 Posted July 30, 2016 Corrado past mot but been told again the hoses need doing.so thought its about time I sorted them.its a 16v with g60 front brakes.any recommendations.cheers Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 31, 2016 OEM or Goodridge braided if you want to spend a it more for mainly cosmetics. Standard hoses should last at least 5 years if installed and bled properly, but they are a maintenance item as the rubber will perish and bulge with age. Quote Share this post Link to post Share on other sites
carrots 1 Posted July 31, 2016 i was going to go for braided stainless .i am not 100% sure what kit i need to order as ive got g60 280mm front brakes and 1.8 16v rear brakes Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 31, 2016 You'll need a set for standard G60 brakes then I guess as all the OEM rear callipers are the same. Note that braided hoses can actually be a danger if not checked carefully every year as the inner rubber hose can perish without having any external warning signs to show it. Quote Share this post Link to post Share on other sites
carrots 1 Posted July 31, 2016 umm didnt think of that Quote Share this post Link to post Share on other sites
