carrots
stuck in 1st gear
I drove 90 mile to a static caravan I am staying in for the week.i got outside the static went to reverse into my parking space to find the car stuck in 1st gear.i drove it a few feet in first and managed to pull it out of gear then into reverse.any ideas
Make sure the Shifter is in the neutral position and the shift linkages on the tower are in neutral, and check the bolts from the cables to the Tower are tight. Worth getting someone in to move the gear stick about sp you can see if the movement is translating to the Tower properly.
