Dub Style 0 Posted July 9, 2004 Wheres the oil temp sensor exactly, theres two near the oil filter but dont know which one Quote Share this post Link to post Share on other sites
dinkus 10 Posted July 9, 2004 There are 2 - one for the ECU and one for the MFA (trip computer), which one do you want to replace? Quote Share this post Link to post Share on other sites
Dub Style 0 Posted July 10, 2004 dinkus, the one for the MFA Quote Share this post Link to post Share on other sites
dannyrado 0 Posted July 13, 2004 just sorted out probs on mine! Bought a new sensor, (at the back with the green wire with black trace) didn't work! Worth noting there sould be a resistance between that wire and earth, and it should alter as the temp goes up, (the resistance goes down as temp goes up if i remember correctly (negative temperature co-efficient)) Any ways it turned out to be a loose connection on the big multi-connector, to the right side of the engine block, i cleaned it up with electrical contact cleaner and made sure i tightened the connector (it's a screw up type.) Christ that took a while! Danny. :D Quote Share this post Link to post Share on other sites
Guest Posted July 13, 2004 There's only one oil temp sender on the VR6 - it's the black & green wired one on the top of the oil filter housing. The ECU doesn't use oil temperature as a control input - it's purely for the MFA. Quote Share this post Link to post Share on other sites
bad2vbone 0 Posted November 3, 2004 Hi. I'm a bit concerned about the temperature my VR6 is running at. However I noticed if i read say 124, turn off the engine, then immediately turn the ignition back on, it will read randomly between 10-20 degrees lower. Is my sensor nackered? I'm a newun to this forum and VR's by the way! Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 3, 2004 There's only one oil temp sender on the VR6 - it's the black & green wired one on the top of the oil filter housing. The ECU doesn't use oil temperature as a control input - it's purely for the MFA. I suspect the other will be an oil pressure sensor :wink: Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 3, 2004 bad2vbone, Welcome to the forum m8 8) Oil temps of 124 degrees are not uncommon - your sensor may well be working correctly. MFA updates itself every few seconds - this is why it gives a different reading when you turn your engine back on. Quote Share this post Link to post Share on other sites
Guest Posted November 4, 2004 There's only one oil temp sender on the VR6 - it's the black & green wired one on the top of the oil filter housing. The ECU doesn't use oil temperature as a control input - it's purely for the MFA. I suspect the other will be an oil pressure sensor :wink: The other TWO are indeed oil pressure sensors, I was correcting above poster who thinks there are two oil temp senders. :roll: Quote Share this post Link to post Share on other sites
Guest Posted November 4, 2004 Hi. I'm a bit concerned about the temperature my VR6 is running at. However I noticed if i read say 124, turn off the engine, then immediately turn the ignition back on, it will read randomly between 10-20 degrees lower. Is my sensor nackered? I'm a newun to this forum and VR's by the way! If you mean that the reading is different when the engine isn't running, I'll give you a clue - the alternator stops charging when the engine stops, what do you think happens to the voltage across the battery terminals? Another freebie : a high post count around here doesn't necessarily indicate an expert, especially with VR6s. Quote Share this post Link to post Share on other sites
