rickdonald 10 Posted October 7, 2016 (edited) - 1992 - Corrado G60, Dragon Green, 11 Months MOT, 210,000 miles but runs spot on, doesnt burn oil and plenty of power. Body - Generally good condition, usual stone chips and a scuff on the front bumper, but no real dents or peeling lacquer. Only rust I can see is on the doors, no rust underneath, sills are good, no rust on arches, rear join lines or filler cap. - Windscreen was replaced twice last year, the second time it went into the body shop where all the rust was cut out and replaced professionally. Then was re-sprayed and blended down the roof. - 16x8” rota slipstream wheels refurbished in standard colour. - Custom HID projector retrofit in headlights, good clean beam! Easily reverted back to stock if required. Engine - Supercharger rebuilt (15 000 miles ago, by Only Charged Dubs) stage 4 charger, fitted with new braided oil feed and return line. - 65mm pulley with G-Werks chip, supplied with 68mm pulley and SNS chip also. - Bahn Brenner outlet - New engine mounts with VT rear engine mount - When supercharger was out being rebuilt I cleaned and painted the engine, replaced ignition system and vacuum lines, replaced coolant and oil sensors. - Mocal oil cooler fitted. - New “hot climate/towing pack” radiator fitted to give a bit of extra cooling. Suspension - Koni adjustable dampers within Konigsport coilovers - In the 10 000 miles it has had new control arms (with TT bushes), ball joints & top mounts Brakes - Porsche Boxster S front calliper conversion with 305mm (Ibiza Cupra-R) discs - Mk4 rear brakes with new discs and pads - HEL performance braided hoses Interior - Fully stripped out, cleaned, then sound deadened with “dynamatt” everywhere. - Extra layer of sound insulation under carpets, behind door cards and trim panels (including roof) - Fixed steering column (spare adjustable provided) - “Dave16v” Short shift kit fitted with new bushes - Aftermarket heated seat elements with hidden switches (under gearstick cover) - Alpine Bluetooth headunit with handsfree, uprated speakers (in standard positions) 5 channel amp and sub in box in side of boot. Loads more that I have probably forgotten... Spares - Low mileage cylinder head - 4 Branch Stainless exhaust manifold - Roof Rack - Adjustable steering column & Cowl - OEM dampers & lowering springs - Box of various suspension components Suspension, Engine, charger, cooling, interior and brakes have all been reworked, my plan if i was keeping was to swap out the exhaust manifold and the cylinder head as one of the exhaust manifold studs had snapped, so is abit of a blow when cold, also was going to get a diesel gearbox in it to lengthen the ratios abit. But other cars mean i dont drive it as much anymore so it is just sitting not really getting used. I'm after £2500 ono. Car is located just outside Chelmsford, Essex. give us a shout if you have any questions (07946792666) [ATTACH=CONFIG]84668[/ATTACH][ATTACH=CONFIG]84669[/ATTACH][ATTACH=CONFIG]84670[/ATTACH][ATTACH=CONFIG]84671[/ATTACH][ATTACH=CONFIG]84672[/ATTACH][ATTACH=CONFIG]84673[/ATTACH][ATTACH=CONFIG]84674[/ATTACH][ATTACH=CONFIG]84675[/ATTACH][ATTACH=CONFIG]84676[/ATTACH][ATTACH=CONFIG]84677[/ATTACH][ATTACH=CONFIG]84678[/ATTACH][ATTACH=CONFIG]84679[/ATTACH][ATTACH=CONFIG]84680[/ATTACH] Cheers Richard Edited October 16, 2016 by rickdonald Quote Share this post Link to post Share on other sites
Dogma 10 Posted October 7, 2016 Some pictures would be nice Good luck with the sale. :) Quote Share this post Link to post Share on other sites
rickdonald 10 Posted October 7, 2016 Some pictures would be nice Good luck with the sale. :) Yeah, I have tried 3 times already and also with my phone but it isn't having it! Any suggestions? Quote Share this post Link to post Share on other sites
Dogma 10 Posted October 7, 2016 There is a limit on the size of the files, can't remember what that is tho.. sorry You could upload them to flicker or some thing like that and then link them I guess. (sorry not much help i know) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted October 7, 2016 Yeah, I have tried 3 times already and also with my phone but it isn't having it! Any suggestions? if windows platform - google windows image resizer, install & then it is as simple as select the pictures, right click & select resize then choose medium & hit ok - you will then have the original image along with the (medium) version of it i know they will work as this is what i do lol Quote Share this post Link to post Share on other sites
rickdonald 10 Posted October 7, 2016 if windows platform - google windows image resizer, install & then it is as simple as select the pictures, right click & select resize then choose medium & hit ok - you will then have the original image along with the (medium) version of it i know they will work as this is what i do lol Done! yeah they were too big. cheers guys! Quote Share this post Link to post Share on other sites
waski186 10 Posted October 9, 2016 are You able to sell sns chip only? PM me if yes with the price and specification... Quote Share this post Link to post Share on other sites
