Bfstrachan 10 Posted December 2, 2016 I have the engine out and the front end off, so thought it would be a good time to replace the wishbones. Got all the bolts off clean, but can't get the rear free from the subframe. Am I missing something or has the bush just seized onto the subframe? Having the same issue with both sides. The bushes are no longer in the control arms, meaning both bushes are no longer held in their pressed position, the control arms are moving freely around. Just can't get them out of the subframe! Am I ok to use some force as I'm fitting new arms with the bushes already pressed? Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 2, 2016 Impressive, most people get stuck at the bolt removal stage as they wind up seized... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 2, 2016 the rear does has a slotted bit it fits in, so you have to pull it forward iirc Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 2, 2016 the rear does has a slotted bit it fits in, so you have to pull it forward iirc Thanks for the help. Forward as in, toward the front end of the car or forward as in pulling from the wheel arch outward? Thanks! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 2, 2016 Found a pic of the lip/slot here http://www.clubgti.com/showthread.php?275870-Poly-bush-help-please But yeah the arm comes out towards the front end of car. They can be a git to get in/out i've found. Definitely helps to have both front wheels off the ground Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 2, 2016 Oh, and to remove the roll bar while I'm at it - do I need to drop the subframe at all? And if so, do I need to do anything with the steering rack? Again thanks for any pointers :) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 2, 2016 Found a pic of the lip/slot here http://www.clubgti.com/showthread.php?275870-Poly-bush-help-please But yeah the arm comes out towards the front end of car. They can be a git to get in/out i've found. Definitely helps to have both front wheels off the ground Ok, I have the whole front end off and the engine out. I am swapping engines and decided to dig a little deeper... Hopefully the hole will begin to fill in :) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 9, 2016 Got the wishbones swapped out - phew!!! Need a pointer on the roll bar drop links. The fitting position - dot you split the bush above and below the housing in the wishbone? I'm thinking yes, but when I took the old ones out they were simply bolted complete to the wishbone? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
