carrots
Strange tensioner on my Kr engine
I changed the cambelt on my 1990 1.8 Kr today but had to refit the old tensioner because the new one was not wide enough to fit the belt.strange thing is the old tensioner was catching the plastic belt cover so I've had to grind a bit of the cover off.the old tensioner was a Ina part 22008301 don't no what's going on
Did the cambelt come with the tensioner as part of a kit or did you buy separately? If a kit the send it back, if not then I'd try to buy one that is.
I would check that, as you should not have to modify anything with something as important as a cambelt
