Gti_Jamo
Anyone familiar with removing an old Cobra alarm?
Hi there,
Basically my alarm has never worked on my G60 and the fob for the immobiliser is broken so decided the best option is to remove the whole thing. Now I have removed most of it without any issues and everything was fairly straightforward, however I have one wire that was connected to the alarm module that I cannot see where it should go. It's a red/yellow wire that goes into the loom from the fusebox side and to the injector loom, I'm assuming it has a home somewhere in the fuse box but cannot see anything obvious.
Cheers mate. Slightly different model of alarm though. However this morning I got my head right in about it and found where the wire goes into the fusebox, roughly behind where the fuel pump relay is located. Just been snipped flush with the connector so couldn't see it.
