VR6 Lee
VR6 clicking noise - Any ideas?
Since my car has come out of its winter hibernation I am getting a clicking noise from the engine. The noise seems to be coming from the area marked in black but without taking the manifold off I can't really see anything. The noise is like a switch clicking on and off.
There is no pattern to the clicking noises.. it will happen say at 1 seconds and then you might get 5 in a row and then off for 13 seconds and then only 1 click... very strange
Any idea?
Probably sticky tappets . Mine has not been started for around 6 months due to work being done on the car .I knew it would be tapping and clicking a bit . It's now been started around 6 times and left to warm up.shes now back to her quiet self when starting. Put a vid up for people to hear the noise .
Plug lead arcing?
Yeah, per Harrier earlier, ie : Plug lead arcing ?
a likely suspect indeed, as I had very similar symptoms recently of a variable & intermittent 'clicking' / 'spitting' noise, and an accompanying misfire that was accentuated under heavy load at low revs - issue traced straight to one HT lead that had developed a break-point at its connector housing ...
... my arcing 'clicking' noise & its misfire were completely sorted with new HT leads
I hope this helps, Lee, and that your situation proves to be a similarly easy fix
