Jon_vr6 1 Posted March 30, 2017 Hi guys Quick question doing a service on the raddo tomorrow and ive never changed the spark plugs myself always a garage. Got all the gear plug lead remover, 10mm socket for the spark plugs but one question is when installing the new spark plugs do i need to put any grease/anti seize type product on the threads before i install them? What type, links? Cheers Jon Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 30, 2017 I've never put anything on the threads Jon . They've always come out easy enough at servicing time . Some older cars used to have to have grease on the plug threads due to rusting, the Corrado does not suffer from rust on the head , so I see no reason to do this . Kind regards Rob Quote Share this post Link to post Share on other sites
Rado87 10 Posted March 30, 2017 Don't think you need to mate to be honest. I like to use copper grease on threads but didn't bother on my VRs plugs. I would say that if they don't easily turn in by hand with a long extension then use a tiny blob of copper grease rubbed into the threads. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Hisnibs 10 Posted March 30, 2017 The other thing I'd recommend is one of them extended magnetic socket things from Halfrauds. Makes it sooooo much easier. The NGKs were 16mm on mine though. Quote Share this post Link to post Share on other sites
Rado87 10 Posted March 30, 2017 Some spark plug sockets have a rubber insert in them that hugs the plug body. Spot on they are. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Hisnibs 10 Posted March 30, 2017 Yeh, anything like that to guarantee the gappidge isn't disturbed n'that Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 30, 2017 Hisnibs said: The other thing I'd recommend is one of them extended magnetic socket things from Halfrauds. Makes it sooooo much easier. The NGKs were 16mm on mine though. Should be 10mm mate standard on vr6 Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 30, 2017 Thanks guys Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Hisnibs 10 Posted March 30, 2017 Jon_vr6 said: Should be 10mm mate standard on vr6 Sent from my SM-G930F using Tapatalk https://www.ngk.com/product.aspx?zpid=9310 Quote Share this post Link to post Share on other sites
Rado87 10 Posted March 30, 2017 Are they a 10mm thread size and 16mm socket size?? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 30, 2017 Sounds right to me. A 10mm socket definitely wouldn't remove a spark plug Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 30, 2017 Just checked my socket and it says 10mm on the side but isnt 10mm inside more like 16mm like you said. Like you said 10mm could be thread size as the other spark plug remover i have in the halfords pro set is has 14mm on the side. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 1, 2017 Thanks everyone for the tips all worked out great just the usual pain of getting the ht leads back on again. Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
robrado974 1 Posted April 1, 2017 I bought the metal one off eBay Jon . Right pain in the arse to put the lead on , twist it and not pull the lead back off again !. Then I looked in the boot and found the oem plastic one that comes with the car doh !. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 1, 2017 Yeah the metal one just seemed to push down the spark plug lead and get stuck. Anyway I got there in the end. Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
robrado974 1 Posted April 1, 2017 I widened the end , so it would release the lead . Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 2, 2017 👍 Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Storm Guy 0 Posted February 12, 2019 Please can someone kindly help with my confusion.... What is the actual size of socket needed to remove plugs. (Lead removal tool no probs). The NGK 3964 BKR5EKU as below (and as ordered), indicates a 16mm hex socket will be required. Thread size at 14mm. https://www.ngk.com/product.aspx?zpid=9315 However the following thread, and some others, indicate a 10mm for the VR (which seems rather small) - http://the-corrado.net/showthread.php?28720-Spark-Plug-Removal-What-size-socket-for-a-VR&highlight=spark+plug+removal So is the thread on standard plug 14mm with a very small hex.at 10mm and a 5EKU with a 16mm hex. Just need to get the right sized plug socket to remove and install if different sized hexes on the plugs. Thanks Quote Share this post Link to post Share on other sites
Cressa 46 Posted February 12, 2019 I changed mine last month. Definitely 16mm with the NGK. Do a search for a vr6 spark plug removal tool. It's a deep socket with a pivoting bar and makes the job really easy. Plus you have a shiny new tool for your toolbox I hope that helps Goodluck Quote Share this post Link to post Share on other sites
Storm Guy 0 Posted February 13, 2019 Cressa said: I changed mine last month. Definitely 16mm with the NGK. Do a search for a vr6 spark plug removal tool. It's a deep socket with a pivoting bar and makes the job really easy. Plus you have a shiny new tool for your toolbox I hope that helps Goodluck Excellent - many thanks for your help! Will sort the tool now. Cheers Quote Share this post Link to post Share on other sites
