1200 bandit
Engine mounts
Just pick up the corrado,when tacking up drive the is a knocking/movement l think it is engine mounts worn.is the 3 mounts? Are the ones on eBay any good
Also looking for gear linkage repair kit as gear lever is sloppy ,is the a full kit available
I would stick to OE for the engine mounts, and a lot of people slightly uprate the front engine mount.
As for the the gears, the stick has a cable connection, it's always a bit sloppy.
Sent from my ONEPLUS A3003 using Tapatalk
I have some spare be and new mounts. Don't have the gearbox one though
Sent from my SM-G357FZ using Tapatalk
It's worth replacing the engine mounts if they've never been done, but your knocking on taking up drive would also possibly point to CV joints or just slack in the drive train. Old cars get sloppy gearboxes and diffs, all that play translates into a difficulty to put drive on/off smoothly.
