123jamesrob
Windscreen seals
Need the passenger side seals as mine is leaking every time it rains. Being in North Wales that's most of the time.
Thanks
Is it the hockey sticks you need? Or the wrap around seal. Have both
Sent from my SM-G357FZ using Tapatalk
Educate me. I'm honestly not sure pal. It's leaking and I can see it running down the foam on the inside of the window
They are bonded in mate so the bonding may not be right. Have you had the screen replaced?
I was guessing it was an issue with the gluing. I've personally not had it done but it may have been done in the past. Pretty much stuck with the best solution for it. I've seen a few feeds about people filling it with silicon and it not working. Not too sure what to do
Ideally you need to identify the exact spot mate
That I have done, yellow insulation tape solved the issue for a day . Is there any type of bonding stuff I can get hold of what will sort the issue?
Try sikiflex mate it's the bonding agent for windscreen any motor manufacture shop will have some
