turbotaxi
R32 fan,which ones?
Hi
I'm currently doing a r32 conversion in my 95 vr
What fans do I use?
Do I also keep the standard fan control module?
Thanks
(Apologies if this has already been covered)
Keep fan module, use spal/revotec/comex/eBay special. Got my comex (revotec) from Burton power I found were cheapest. Combined with some custom fan brackets from a group buy a while ago.
You will lose the 3 speed unless you want to mess around with Resistors, I didn't want to risk messing with Resistors and heat in the engine bay so wired them all up together.
Sent from my SM-G930F using Tapatalk
Most people use a 9" and an 11", that's what I have
Yeah all speeds are same if you bridge them..... works a treat though. I do hear a tiny drop between speeds as it switches speeds
