TrumpieVr 10 Posted June 5, 2017 Hi, I'm after the a black center plastic bezel that will fit a 94 VR6 (this is the bit that the radio and heater controls fit in) as mine has crack and fell apart. If any one is breaking and has one please get in touch. thanks Quote Share this post Link to post Share on other sites
fla 9 Posted June 5, 2017 Might be easier to plastic weld and strengthen the break with some wire. Thats what did. Quote Share this post Link to post Share on other sites
TrumpieVr 10 Posted June 5, 2017 Cheers Buddy, Will give this a go once I've got another in case I F***k it right up, what plastic weld solution did you use? Cheers Quote Share this post Link to post Share on other sites
fla 9 Posted June 5, 2017 I used some tie wraps to melt onto the split with some copper wire pressed into the joint for more strength. I've got an adapter to put on the end of the soldering iron so you can feed the repair material through. Quote Share this post Link to post Share on other sites
TrumpieVr 10 Posted June 5, 2017 Great thanks for that I'll see if I can take down an adapter for my soldering iron and have a go at repairing it if I can't find a replacement. Although mine is broken so not sure if this will hold together as not just a crack repair. Quote Share this post Link to post Share on other sites
