1200 bandit
None start
Got a 1993 VW Corrado 2.0 16v
Went to get the rear windows tinted today,looking really nice drove to work no problem
Drove the Corrado home drives really good with no problem (about 5 miles)stopped outside the house open the garage up try to start will not start. When turn the ignition on no ABS light on dash,
The engine cranks very well,when cranking the engine the ABS light comes on the dash
Have good spark, have petrol up to the vavle by the air filter have petrol up to the 5th injector.the petrol is fresh.The is no alarm fitted no cut out switch fitted
Remove the spake plug ,spark plug dry ,Can hear the fule pump working
Have removed the wiring to the ABS pump looking clean
Any information will be appreciated
Got up this morning,thought I just give a try engine starts ups and running ok
But now l have no ABS light at all, turn the ignition on no abs light start engine no abs light on
Has abody had a similar problem
Its common for the bulb to blow on the dash light, start the car with your foot on the brake pedal, can you feel it pulse as it does its pre start checks?
Update, turn on the ignition on,no ABS light, crank the engine ABS light on when cranking,engine starts no ABS light on,Removed the wiring block from the ABS pump light on dash,Have not been out in the car to see if the ABS works on the road but never had to use it so don't know if it has ever worked
The engine starts and runs grand
