fla 9 Posted June 30, 2017 Quick one - how far in should this go on tbe card? Mine seems to shake loose from the cards after a while. Should the door card go right to the end if the slot under the longitudinal rubber grips? Thanks Quote Share this post Link to post Share on other sites
leon263 0 Posted June 30, 2017 (edited) There should be a number of metal clips which hold the trim in the correct position. I can't remember if they clip onto the edge of the door card or onto the trim but in any case I have four here which you are welcome to and I'm sure you'll work it out. The purpose of the clips is to lock the door card into the trim and eliminate your problem. Have a look at the diagram below, the trim is number 17 and the clips are number 9. It looks as if the clips might actually be on the lower edge of the slot in the trim with the tongue part inside the slot. PM me your address if they are any good to you. http://www.realoem.me/Volkswagen/RDW/COR/1994/76/R/8/867/177000 Edited June 30, 2017 by leon263 Quote Share this post Link to post Share on other sites
