steveo29
g60 slight stumble from idle /low revs
my g60 has had an annoying random stumble
when going from coasting , say going around a T junction or sharp corner then onto the gas it sometimes has a slight stumble then carrys on as normal , cant make it repeat itself and doesnt seem to be any pattern , idles fine , pulls fine
everything is in good order , quality service parts etc
cam and ign timing checked
o2 sensor unplugged makes no odds
tried some plugs and leads
any ideas please
Hard to diagnose if it is so infrequent. As it is happening as you come onto throttle, have you had a look at the throttle body? I wonder if the idle micro switch is a bit gummy so when you accelerate it is hesitating. Cleaning the throttle body, and adjusting the switch a little may help.
Have you checked the basics such as timing and co pot resistance? I know it is intermittent and is running fine otherwise, but you've got to start with the simplest stuff.
switches do check out ..but yeah have to wonder if its sticking once in a while
did wonder if injectors dribbly or funny pattern , but then it idles and seems fine most of the time
