1200 bandit
Scanner
Have just got a scanner and a adapter lead,the scanner will not communicate with the corrado
It is a cheep scanner it will go through the start up sequence but will communicate
So the question is what scanners will communicate with a Corrado (that doesn't cost a weeks wages)
What scanners are people using :scratch:
Yes,ignition on, l think the software is not compatible with a early car
I thought it might because it is a 16 pin.but l will use it on something else
Anboby uesing a scanner that's works on a 1993 2.0 corrado
PS no question is silly as sometimes you can over look what is right front of you
Edited by 1200 bandit
