turbotaxi 10 Posted July 14, 2017 Hi I'm in need of the bonnet release clip The part in the middle that looks like a screw [ATTACH=CONFIG]87575[/ATTACH] Quote Share this post Link to post Share on other sites
easypops 8 Posted July 14, 2017 I think you can use one that has the screw on the side, but with the screw removed. Or I was talking to someone who drilled through an aluminium golf tee to make a substitute Quote Share this post Link to post Share on other sites
turbotaxi 10 Posted July 14, 2017 Thanks pops,will have to modify if I can't find one But would be easier if I can get any of those parts Quote Share this post Link to post Share on other sites
easypops 8 Posted July 14, 2017 Thanks pops,will have to modify if I can't find one But would be easier if I can get any of those parts The part with the screw is readily available from VW heritage Quote Share this post Link to post Share on other sites
turbotaxi 10 Posted July 14, 2017 Thanks but need it before the weekend as cars going in for exhaust Quote Share this post Link to post Share on other sites
easypops 8 Posted July 14, 2017 Thanks but need it before the weekend as cars going in for exhaust Ah, ok. Perhaps you should let people know where you are in the country as someone local might be able to help Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 14, 2017 If you get stuck , tie a wire around each bonnet rod and remove the grill . Then you can close the bonnet as normal. Quote Share this post Link to post Share on other sites
turbotaxi 10 Posted July 14, 2017 I'm in Luton (thought it will show up) Thanks rob I'll give that a go Quote Share this post Link to post Share on other sites
