1200 bandit 10 Posted October 12, 2017 Have got some xs play in the gear linkage,got a gear linkage bush kit ( from eBay) What's the best way to replace the gear linkage bushs, not looking forward to carrying out this job Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted October 12, 2017 What part has the Bushes? The lever linkage? The shift tower? Corrado 02a gearbox I assume or golf 020? Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted October 12, 2017 If the lower gear level cover is pulled up l can see a white bush on the bottom of the lever which is has xs play,I have got a gear linkage kit from eBay Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 13, 2017 If the lower gear level cover is pulled up l can see a white bush on the bottom of the lever which is has xs play,I have got a gear linkage kit from eBay Yep this is the one that always wears, not worth swapping the others. Easy enough to remove, stretch the new one over the ball with long nose pliers. Quote Share this post Link to post Share on other sites
