JAM11E 10 Posted October 25, 2017 HI All Noticed a chip on my timing chain sliding rail today, will this cause a problem? Obviously i would like to replace it....can you purchase the part on it's own? If so from where. Jamie [ATTACH=CONFIG]89741[/ATTACH] Quote Share this post Link to post Share on other sites
fla 9 Posted October 25, 2017 Should still be available from the dealer. Problem is, though, its a gearbox off job. Why? Because the mounting pin is in the lower side cover plate section. Whilst the gearbox is off its worth replacing all the guides, main crank seal and perhaps even doing the chains. Quote Share this post Link to post Share on other sites
