Helmert3 11 Posted May 22, 2018 Hi Guys So I've been attempting to get my dad's old Corrado going again, which has been all well and good asside from the fact there is no spark, which I believe I have mailed down to the Hall Sensor, which is only recieving 0.03v (https://cdn.discordapp.com/attachments/355098188312477698/448226087776813073/IMG_20180521_160047.jpg) - Image of voltage I have absolutely no idea what it could be, as I have changed the ECU Relay, cleaned up all the others, therenis grounding to the ECU, and grounding has been cleaned up on the battery, as these were originally slightly corroded. Some guys over on Reddit believe it might be the ECU, in which case things might proove a little bit harder to investigate/fix. There is also a solid 12v (Well actually slightly Under, around 11.7v) at the coil, and there is some form of resistence at the Coil/Hall Sensor which will then return to 0 again. Appreciate any help, as I'd love to get this car going, and ready to drive at some point soon. Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted May 22, 2018 Could you not just run a separate 12v feed directly from the coil to the hall sensor and see if it fires up? Quote Share this post Link to post Share on other sites
Helmert3 11 Posted May 22, 2018 Wouldnt that cause an issue due to the ECU not sending the signal? Quote Share this post Link to post Share on other sites
