carrots
02a driveshaft seals
How far do i knock the driveshaft oil seals in.ive just knocked um as far as they would go.have i done right.cheers
Mine were sitting flush with the gearbox casing before taking the old ones out.So I just knocked the new ones into the same position.
The seals have a double lip that runs on the plated journal of the driveshaft cups. There might be a witness mark on them where the old ones ran on them.
Sent from my Moto G (5) using Tapatalk
Oil seals are normally pressed fully in to seat on a machined lip in the gearbox casing to keep them square in the bore, so you should be ok if you have used the correct oil seals.
