corrado_sunderland 0 Posted August 21, 2018 Well we could not find a clean Rado so ended up with a little run around Scirocco. Now as usual the carb is missing bits and not running right so i need a new one. If anyone has one lying around please let me know :) Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 23, 2018 I'd go for a Webber carburettor as the original Pierberg ones were pants, I had one on my 1.8 Scirocco Scarla, it had the wax stat type auto choke on it, which are known to wear out, I had to put at least 2 on mine. Plus they have that large green ball type vacuum chamber that is bolted to the bulkhead, they can cause problems as well over time. Also check the thick rubber base mount, as they crack and cause rough runing. If you do fit a Webber carburettor you'll have to fit a manual choke cable, normally fits into dash on drivers side just left of steering wheel. Si Quote Share this post Link to post Share on other sites
