robrado974 1 Posted October 10, 2018 I suppose now I need a vagcom , as I’m out of ideas . The ISV has been cleaned. The ISV has been changed. I’ve had all the vac hoses off and there are no splits. I’ve cleaned the plugs to the vac lines . The MAF has been pulled whilst the engine is running and the note changes and it starts to stall. I also experienced a loss of throttle / power which I think was fuel related. I’ve fitted a new fuel filter. Obviously the new filter was dry and it took two turns of the key to fire, I would think this rules out the pump , if it was on its way out it should have struggled I would of thought. The FPR is only a few years old too. The plugs have only done 1500 miles or so . The ignition leads are 1500 miles too. Dizzy is fine and the rotor arm . I’ve cleaned the throttle body too, ok so it was still on the car but ive opened the butterfly and got in as far as I could. So I think the only option is now a vagcom check . Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 10, 2018 Vagcom would be a good idea, might give a suggestion of where to look. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 10, 2018 I think I will be clutching at straws otherwise Jim . I could spend hundreds replacing parts I don’t need until I found the problem. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 21, 2018 I’ve had another check this weekend. I knew it wouldn’t help but it can’t help to try . I sprayed easy start to check for vac leaks again . The coil has been changed. I’ve fitted new plugs . I’ve removed the BMC , just in case it was dirty and playing the MAF up. I’ve unplugged the ISV , whilst the car is running and it made a difference so it’s working,I then fitted another working ISV , just in case . Result . It’s still the same sketchy idle . Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 21, 2018 Is it just the idle? Does it run ok apart from that? Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 21, 2018 Yes jim . Pulls like a train . Maybe I have narrowed it down to the potentiometer?. I’ve checked the wires to the electrical plugs too. They are wrapped well and no amount of wiggling alters anything. Quote Share this post Link to post Share on other sites
