akacheesy
Autochoke issues
I'm having intermittant problems with, I think, the auto choke. From cold it will start then rev to about 1500rpm for a few secs then completely die. had it in to the garage & the so-called mechanic said he couldn't find anything wrong with it i.e there's no fault on the comp. He said to keep an eye on the water levels as it maybe the head gasket, which i think is a complete load of bollox.
Any suggestions??
Is it OK when hot? Might be the blue temp sender, which is on the thermostat housing on the front of the engine engine block, behind the rad fan. They're about a tenner, so a cheap fix it it works and not the end of the world if it doesn't!
Yup its fine once its been running for 5mins or so. Its just the initial start in the morning when its problematic.
I'll take a look tonight see if i can find it
Thanks m8
