rickdonald
Clearout - 4-cyl Subframe, Suspension, steering, interior, HVAC, Controls, alternator
Subframe, suspension, HVAC, interior and other bits For Sale
A long overdue clear-out, over the last year I have done a fair bit of work on my TDI (including swapping sub frame for a VR6 one, suspension, HVAC system and interior).
All this needs to go to free up some space.
Happy to sort shipping etc. but given the size of most bits I just wanted to get the advert up initially. Also I’m based in Chelmsford, work in Basildon and travel up towards St’Helens/Wigan fairly regularly so can also drop stuff off in near-by areas:
Fixed Steering column – New Bearings top & bottom. - £50
Fixed steering column cowl (early level – but modified to fit late style hazard switch) - £20
HVAC box with cables & motor – good condition, flaps recovered with new foam, motor a bit squeaky on speed 1, no heater matrix as was leaking. - £60
HVAC controls (late level) – good condition, all working, no damage to tabs or mech- £100
Cloth interior (Late) – Worn drivers bolster foam but no rips. Front seat lower side plastic missing. Small hole in rear bench fabric. Front door cards cut behind speaker covers to take larger speakers (cannot see when fitted) - £150
FK/Koni damping Adjustable coilovers (FK Konigsport - Koni top adjustable dampers). – could do with a rebuild, very small bit of pitting on front pistons & one of the rears has a small leak. All adjusters and collars are free and moving. - £70
Standard wiper arms -£5
4-Cyl sub-frame – good condition, painted with anti-rust paint. - £50
4-Cyl cross-member – good condition, painted with anti-rust paint. - £30
4-Cyl front knuckles with hubs & bearings – powder-coated good condition. - £50
4-Cyl/Narrow track wishbones with good ball joints – painted with anti-rust paint (have about 2000 miles on them) - £15
Steering rack. no play before removed and no leaks. needs a clean up- £25
4cyl engine mounts & brackets:
Rear bracket (357 199 354 H) £20
Rear mount (535 199 262) £10
Front mount (357 199 279 B) £10
4cyl Tie rods and ends (have about 2000 miles on them) – £10
4cyl tie rods (new) – bought in error - £10
70A alternator 028 903 025 H – removed from 1Z/AHU TDI engine – but should fit VR6. - £40
[ATTACH=CONFIG]97146[/ATTACH][ATTACH=CONFIG]97147[/ATTACH][ATTACH=CONFIG]97148[/ATTACH][ATTACH=CONFIG]97149[/ATTACH][ATTACH=CONFIG]97150[/ATTACH][ATTACH=CONFIG]97151[/ATTACH][ATTACH=CONFIG]97152[/ATTACH][ATTACH=CONFIG]97153[/ATTACH][ATTACH=CONFIG]97154[/ATTACH][ATTACH=CONFIG]97155[/ATTACH][ATTACH=CONFIG]97156[/ATTACH][ATTACH=CONFIG]97157[/ATTACH][ATTACH=CONFIG]97158[/ATTACH][ATTACH=CONFIG]97159[/ATTACH][ATTACH=CONFIG]97160[/ATTACH][ATTACH=CONFIG]97161[/ATTACH][ATTACH=CONFIG]97162[/ATTACH][ATTACH=CONFIG]97163[/ATTACH][ATTACH=CONFIG]97164[/ATTACH][ATTACH=CONFIG]97165[/ATTACH][ATTACH=CONFIG]97166[/ATTACH][ATTACH=CONFIG]97167[/ATTACH][ATTACH=CONFIG]97168[/ATTACH][ATTACH=CONFIG]97169[/ATTACH][ATTACH=CONFIG]97170[/ATTACH][ATTACH=CONFIG]97171[/ATTACH][ATTACH=CONFIG]97172[/ATTACH][ATTACH=CONFIG]97173[/ATTACH][ATTACH=CONFIG]97174[/ATTACH][ATTACH=CONFIG]97175[/ATTACH][ATTACH=CONFIG]97176[/ATTACH][ATTACH=CONFIG]97177[/ATTACH][ATTACH=CONFIG]97178[/ATTACH][ATTACH=CONFIG]97179[/ATTACH][ATTACH=CONFIG]97180[/ATTACH][ATTACH=CONFIG]97181[/ATTACH][ATTACH=CONFIG]97182[/ATTACH][ATTACH=CONFIG]97183[/ATTACH][ATTACH=CONFIG]97184[/ATTACH]
[ATTACH=CONFIG]97201[/ATTACH][ATTACH=CONFIG]97202[/ATTACH][ATTACH=CONFIG]97204[/ATTACH][ATTACH=CONFIG]97205[/ATTACH][ATTACH=CONFIG]97206[/ATTACH][ATTACH=CONFIG]97203[/ATTACH]
Edited by rickdonald
I would like the seats/interior, could pay deposit now pick up later. How far are you from Peterborough
PM'd
  rickdonald said:
Front bracket (357 199 273) £15
Hi mate, I'll have this off you please if you can courier
Cheers
Cheers
Can do for be £18 shipped Royal Main 1st class signed?
thanks
thanks
Great, send me payment details. Cheers
