MarkGolf 0 Posted September 19, 2019 Hi Guys, I've got all 3 vibratechnic mounts, aside from the engine looking like it's sat on the ****, resolved with a shim I made, I find that the engine can be wobbled by hand and if I rev the car, it moves more than I would expect, not enough to hit the bonnet but this just seems a bit loose. Everything is tight as can be. Is this normal for this setup or is there a problem? Thanks, Mark Quote Share this post Link to post Share on other sites
blue95 0 Posted September 19, 2019 Something doesn't sound right mate...had VT on my 4x4 and found them to be superb at minimising movement....sure you haven't overtightened the mounts and sheared the bolt fittings? FYI they don't require torqueing up anywhere near as much as the factory mounts. Quote Share this post Link to post Share on other sites
