fla 9 Posted July 12, 2022 Just doung a few maintenance jobs on the car. One of the hoses to the mocal was slightly split so i cut it off and rejoined it to the coupling. However its just not going further along the fitting as per the photo. Its also pretty hard to remove now without cutting the hose. For this much length will it be ok using a clamp on the hose or should i cut it off and try again? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 29, 2022 Try spraying a bit of silicone spray to ease It all the way in or a pot of boiling water usually softwns the hose end enuff to reinsert. Definatly use a hose clip, my fittings that i used ayons ago to build various oil cooler set ups would Always leak After removing the end, even the barbed end types.. Quote Share this post Link to post Share on other sites
