bopnud 0 Posted December 22, 2022 I have a 1992 corrado slc and it has been making what I can only describe as a clacking noise coming from the timing side of the engine. This noise is worse when it has been outside in colder temps and I noticed today as I filled the car with gas the noise significantly quiets down. Is this a timing chain issue or something else. Thanks. Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted December 23, 2022 Possibly - timing noise starts off being noisey when the engine is cold and quietens when it warms and eventually makes a noise all the time. Any history of them being done? If you do consider using the plastic mk4 tensioner instead of the original metal tensioner. Quote Share this post Link to post Share on other sites
bopnud 0 Posted December 23, 2022 4 hours ago, MJA said: Possibly - timing noise starts off being noisey when the engine is cold and quietens when it warms and eventually makes a noise all the time. Any history of them being done? If you do consider using the plastic mk4 tensioner instead of the original metal tensioner. I went ahead and ordered a timing chain kit from urotuning so I can update once that goes on. Quote Share this post Link to post Share on other sites
