Classico 0 Posted September 16, 2023 Hi Guys, i am working on my new Corrado project and have a problem with the sunroof motor cover. its a 1994 , was standing in a garage for a long time. when i bought the car the last owner had already changed the sunroof frame( i dont know from which vw but everything looks the same as the old frame , it came with the car) and it was just a matter of putting everything back, i thought..... Everything went fine, roof is working and i thought i finished the job but then saw there was no possible way to get the sunroof motor cover back . It looks like the motor is to thick? it is the one with the 6 pins. Anyone who can help me solve this mystery? i will try to put some images here Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 20, 2023 An earlier type motor won't fit the later sunroof cover trim - the earlier motors are larger. It's also possible that the prevous owner sourced a replacement motor from a different VAG car with the same pin-out, which will mate up and operate the mechanism. Is there a part# on the unit you have? Quote Share this post Link to post Share on other sites
Classico 0 Posted September 20, 2023 Thanks for the tip! i checked but no part.number , only 1-1 and 7/ 1992 Quote Quote Quote Share this post Link to post Share on other sites
