Classico
Sunroof Motor Cover does not fit
Hi Guys, i am working on my new Corrado project and have a problem with the sunroof motor cover.
its a 1994 , was standing in a garage for a long time. when i bought the car the last owner had already changed the sunroof frame( i dont know from which vw but everything looks the same as the old frame , it came with the car)   and it was just a matter of putting everything back, i thought.....
Everything went fine, roof is working and i thought i finished the job but then saw there was no possible way to get the sunroof motor cover back .
It looks like the motor is to thick? it is the one with the 6 pins.
Anyone who can help me solve this mystery?
i will try to put some images here
An earlier type motor won't fit the later sunroof cover trim - the earlier motors are larger. It's also possible that the prevous owner sourced a replacement motor from a different VAG car with the same pin-out, which will mate up and operate the mechanism. Is there a part# on the unit you have?
