daves16v
Top mounts - where?
Where's the best/cheapest place to buy suspension top mounts for my valver, GSF, ECP, Stealer?
Ta
Yup, they do bumpstops too. I've gone for proper VAG stuff on my car, but where there's a cheaper, just as good alternative I've gone with GSF parts.
I would recommend buying VAG top mounts as the GSF ones ive bought are crap. They flex quite badly when you push down on the wing, maybe its the stiffness of the FK springs thats doing it but i plan to replace them before getting the suspension geometry checked.
As King Prawn says, go for VAG top mounts. I fitted some non VAG ones which failed an MOT 4,000 miles later, and they were totaly shot. I have also seen this happen on mates' cars so it wasn't a one off.
Also, when fitting them, make sure that the bearing is properly packed with grease. If it is not then it is likely to wear out quicker than is should.
The snag is that the mounts are about £30 a pop from the stealer :(
