LJ 0 Posted August 16, 2004 I can't get the frickin pipe out the white clips that secure the solid brake lines to the fire wall. These clips are behind the heat shield cover, underneath the inlet manifold. Anyone have a cunning technique for doing this? I'm only replacing the front brake lines and don't want to mangle the other lines there, and ideally keep the clips intact as they hold the lines in place. Spent yesterday arvo' wishing I had a few more joints in my arms and more strength. ... all because I couldn't seperate the solid line from the flexi hose on the last corner when fitting new braided hoses. I have diddly squat mechanical ability! Also, six line brake system. Obvious where four go but where are the last two flexi hoses? Quote Share this post Link to post Share on other sites
Henny 0 Posted August 16, 2004 the two short flexy hoses go onto the joint of the rear axle where it attaches to the chassis... they're a pig to get at... :| Quote Share this post Link to post Share on other sites
LJ 0 Posted August 16, 2004 Joy, I'll look forward to that episode next then :( Quote Share this post Link to post Share on other sites
andycowuk 0 Posted August 16, 2004 let me just reinforce what henny said...... they are a total bugger to get at. Quote Share this post Link to post Share on other sites
yellowslc 0 Posted August 28, 2004 To release the hardlines from the clips, apply even and outward pressure away from the clip centerline. Replacement of the rear flex lines is a total PITA, I actually installed my SS rear lines lastnight. Be sure to use flare/line wrenches on the hardline fittings, otherwise you will strip them and be totally stuck making new lines yourself. R Quote Share this post Link to post Share on other sites
